Need Help
Old 04-19-2014 | 02:02 PM
Gsmooth33's Avatar
Need Help
Im having problems with something draining the battery on my dads 2005 TL. If the car sits for two days the battery is dead. I have replaced my battery and tested the charging system and everything is fine. Thanks in advance for your assistance
Old 04-19-2014 | 04:44 PM
Nick216's Avatar
The Boss
Check out the hfl.
Old 04-20-2014 | 12:59 AM
Will Y.'s Avatar
Registered but harmless
The HFL/Bluetooth units sometimes continue to stay on more than 30 minutes after the ignition is cut off, thereby causing a continuous drain. Do a draw test on the HFL through the fuse box.
A bad HFL usually requires replacement-- $180 or so in cost, plus a few minutes of time to replace, per several threads here on bad HFL units.
Old 04-20-2014 | 01:44 AM
3RDGENTL757's Avatar
Feel the plastic piece behind your map light, if it's warm then it's staying on or you can press the HFL talk button and see if it comes on if not then it's bad. You can either replace it if u use it or just unhook the HFL unit if you don't use it and save you 150 bucks or so and it only takes no even 5 mins to do
Old 04-23-2014 | 05:59 PM
Gsmooth33's Avatar
Thanks to all for the response.
