Nailing or screwing a Coverlay dash cover into the dashboard?
So like most of you I had the infamous passenger-side airbag crack happen in my 08 Type S 6MT. I purchased a Coverlay dash cover this past summer and glued it on with little issues.
Now that it's winter here in Georgia (which really isn't much of winter but temps still occasionally drop to around freezing) the glue on the back side of the cover closest to the windshield has quit bonding due to the temperature fluctuations when I start the car and use defrost mode on the windshield. I've tried re-gluing but nothing will stick. To make matters worse, since it is loose, the cover rattles against the windshield in the passenger-side corner which drives me nuts. If I were to drill two or three screws into the dashboard to hold the cover in place, and therefore stop the rattling, would that damage any components underneath the dash? Or is there a better solution to this issue? I can't reach very well back near the windshield. |
:facepalm:
why would you consider screws/nails before something simpler like wedging a piece of foam and using just good ol' friction to keep her in place? |
IF you can remove the adhesive from the area where it is not sticky, reapply a better glue or at least 3m double sided tape. Foam can work too like thoiboi stated.
Did you use 3M tape to begin with? That stuff in industrial strength and should hold up fine. Heck, people use it to hold their rear deck lip in place. And it gets exposed to all kinds of elements and high speed wind. No reason it wouldn't work on your dash. Just make sure to stick on a smooth surface and clean it really well.
Originally Posted by mhtut83
(Post 16352148)
https://www.3m.com/3M/en_US/company-...3241071&rt=rud Nail or screw :spanky: |
But If you do go the mail or screw route, I'd suggest no less than 4 inch drywall screws |
:maha:
Thoiboi is being conservative. You need 18 gauge brad nails to do the trick with 150psi compressor |
18 gauge too small.. 10 gauge to be safe
How are you going to get a hammer or screwdriver in there?
:snicker: :rofl: Wait, you should nail it through the window. |
Flexi-tip driver or and an angle-pounder. :co:
If you're at the point of considering screws and/or nails, how about just shooting some expanding foam in the crevice to take up the gap and stop the squeak? |
Just tinker with it, try wedgeing it with something. Definitely don't use screws. My old goofball did that to his Yukon where the clip on the window switch broke... He said he'd screw it, but I didn't belive him until I saw it, lol! Sadly, he now has severe dementia...
if you insist on using a nail, use a small finishing nail and touch a little black paint to it after to hide it... If it's at the base of the windshield, no one should hardy notice it then. But please, try something else first!!! |
Originally Posted by cu2wagon
(Post 16352620)
If you're at the point of considering screws and/or nails, how about just shooting some expanding foam in the crevice to take up the gap and stop the squeak? Good advice! |
That poor TL... |
(Post 16352620)
If you're at the point of considering screws and/or nails, how about just shooting some expanding foam in the crevice to take up the gap and stop the squeak? also, do they make black colored foam :ponder: |
I'm sure they do.
If that doesn't fix it, I suppose filling the crack with some black caulk might fill it up and stop the noise.
Do they make bloating black caulk? |
Ended up wisely using the 3M mounting tape... thanks for the suggestion.
Great! WAY better than giving it the nail!
It must have been annoying to consider nailing it! Also, 3M tape is an appropriate repair for this problem, so atleast you can sleep at night knowing it's not nailed... LOL!!! How does it look? |
1/4" togglers should do the trick :thumbsup:
I'm in the market for a RDX and can't believe there isn't more coverage about this issue. Have there been any updates as far as fixes? I was looking to get an RDX by months end but I might hold off my purchase if this isn't resolved.
Originally Posted by naszero
(Post 16388045)
RDX dashes are all fine, from what I know... The dash problem was on the 3G TL's, 2004-08 MYs... |
That's not going to do jack diddly.
(Post 16448057)
Make it an offer it can't refuse! I would!
Nail or screw?
How about bof! |
Might as well just pull the dash and bolt it on, for good measure...
If you have a Coverlay, please ensure you use a sunshade. Mine warped just above the airbag, and now I have to try to tame my OCD ass and glue it back down. If that doesn't work I'm returning this to Rock Auto where I bought it.
(Post 16450243)
