This camber bolt problem continues
Old 07-30-2012, 05:11 PM
TrixR4Kidz's Avatar
hey guys. i asked on the forum before about removing this camber bolt. it was suggested to try twisting it. i noticed as i twist it, the bushing is twisting also. how do i remove this?
Attached Thumbnails This camber bolt problem continues-img_0579.jpg   This camber bolt problem continues-img_0580.jpg
Old 07-30-2012, 06:05 PM
dzionny_dzionassi's Avatar
you will need hammer, thats how i do it, done that like 10 times
Old 07-30-2012, 06:09 PM
Received 16,260 Likes on 11,971 Posts
unscrew it until there are no more threads left.
then use a hammer and a screw driver!
Old 07-30-2012, 06:17 PM
there are no threads in the fork...
Old 07-30-2012, 06:20 PM
TrixR4Kidz's Avatar
right thats what i thought. so just gotta hammer the little bastard out? i wacked it pretty good not gonna lie lol
Old 07-30-2012, 06:39 PM
yep, just watch the threads. That bolt tip is rounded for a reason. You have to use hammer to take it out ant put it back.
Old 07-30-2012, 07:19 PM
6SPEED FEVER
EATSLEEPRACE's Avatar
Wtf....I wish I would have know this...lol
I fukcing murdered my perfectly good stock bushings...
Old 08-01-2012, 11:30 AM
AndrewA's Avatar
the springs are pushing down on the bolt. i've used a bottle jack to push up on the fork to remove some of that spring tension. that makes it a little easier to tap out that bolt.
Old 08-01-2012, 12:45 PM
TrixR4Kidz's Avatar
hit it literally 100 times with a sledge hammer. it didnt move one bit
Old 08-01-2012, 02:40 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
PB blaster and hammer....
and by hammer, I mean a big fucking hammer and not a mallet...
Old 08-01-2012, 06:02 PM
ok do you have impact gun (ratchet should do the job too)? if yes use it on bolt, the bolt by it self got slots on it (where bolt goes in to control arms bushing) when you gone turn the bolt slots will clear some rust in the bushing. Hope this will helps
cycdaniel
12-17-2019 10:58 AM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
james357
02-13-2016 02:37 PM
DUECE_DXJ
09-24-2015 04:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Quick Reply: This camber bolt problem continues
