my key fob doesn't work that well
Old Sep 9, 2009 | 07:32 PM
CdTriX's Avatar
my keyfob hasn't been working that well lately, i have to point it at the car and if i press lock, and then unlock it doesn't always work,
the trunk doesn't always work
getting the windows to roll down doesn't always work..
it's like the range is very bad and it's not very responsive.
Old Sep 9, 2009 | 07:51 PM
BradE's Avatar
Did you replace the battery in it?
Old Sep 9, 2009 | 08:18 PM
CdTriX's Avatar
brand new switchblade from heeltoe
Old Sep 10, 2009 | 07:27 AM
LoveMyTL-S's Avatar
Does your spare FOB work okay? If so then your new FOB from Mr. Heeltoe is bad and perhaps you should contact him.
Old Sep 10, 2009 | 08:48 AM
BradE's Avatar
It doesn't matter if it's brand new, batteries can go bad. Replace the battery first.
Old Sep 10, 2009 | 10:49 AM
CdTriX's Avatar
my spare fob was doing it too
key 1 fob is okay more responsive but not that much more
key 2 fob is flakey
switchblade is flakey
i end up having to wait 10 seconds between button presses and the truck i have to try 2-3 times to get it to pop open
Old Sep 10, 2009 | 01:32 PM
LoveMyTL-S's Avatar
Hmmmm, may be the actual receiver in the car. Not sure exactly where it's located. But I think it's up front somewhere. Sorry, I'm not much help.
Old Sep 11, 2009 | 11:51 AM
CdTriX's Avatar
Old Sep 11, 2009 | 11:56 AM
CdTriX's Avatar
for the test, do i use a multimeter from pin 1 to the other pins to check for voltage?
Old Jun 14, 2010 | 11:44 AM
NCTL05's Avatar
Middle Finger anyone?
Nothing like a thread resurrection!
I would like more info on the above please? My key fob does the same crap.
Old Jun 14, 2010 | 03:34 PM
dob0308's Avatar
3rd Gear
If your range doesn't seem far enough...try holding the fob against your chin while pressing the lock/unlock button. Some fobs have extended range like this.
I can't speak for my TL (never had to try), but it works for my BMW.
Old Jun 14, 2010 | 08:16 PM
NCTL05's Avatar
I tried with the TL, but the problem I have really isn't with range. It is with the randomness of the thing actually working. And yes the battery is fine.
I was kinda hoping someone could elaborate on the testing procedure above for the key fob reciever...The whole part 4 for testing the leads of the plug. I didn't really understand that. What tools would I need anyways?
rockyboy
Aug 4, 2024 10:35 AM
AndrewS
19
Mar 14, 2024 06:59 PM
tman570
Jun 11, 2019 07:56 AM
acurajj
Sep 19, 2015 03:47 PM
asahrts
Sep 4, 2015 05:55 PM
