auto off headlights dont work?
Old 06-13-2010, 01:14 AM
gcxandrew's Avatar
hi i have my keyless memory setting to turn my headlights off automatically after 15 seconds, but my headlights always turn off instantly after i shut my engine off. does anyone know how to make them stay on for 15 seconds after i close the driver door? any help would be appreciated
also one more question, when i put it in reverse only the driver side mirror tilts down and the passenger side stays the same. is that normal?
thankss
Old 06-13-2010, 01:29 AM
SpiderX1016's Avatar
Not sure of the first question. Mine works perfectly, never had a problem with it.
but there is a little switch on the left next to the door handle. Where you can adjust to mirrors and turn on the heated mirrors.
There is a switch labeled (L, Off, R). Choose L or R for whichever one you want to tilt down in reverse.
and it's normal for just one side to tilt down.
Old 06-13-2010, 01:36 AM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
for that to work the headlights need to stay in the ON position and not auto as far as I know.
Old 06-13-2010, 03:14 AM
Chapter Leader (San Antonio)
TheChamp531's Avatar
First, both the passenger and driver side mirrors should tilt.
Second, are you sure your headlights are on to begin with? I mean if you turn off your headlights manually, it won't come on. It will only stay on for however long you set the settings too when you leave it on.
Old 06-13-2010, 03:03 PM
CARBON FIBER WDP TL
poormans_tl69's Avatar
check the setting my boys car did this and all i did was play with the settings and make sure the lights stay on
Old 06-13-2010, 05:00 PM
Fear and Loathing in my
Timb227's Avatar
Not sure about the lights, make sure they are in the auto, or on position.
Only ONE mirror will tilt down at a time, depends on which one you select.
Old 06-13-2010, 10:28 PM
gcxandrew's Avatar
hmm thanks for the answers that solves my mirror question
its weird though my headlights are on AUTO but they still turn off instantly after i shut my engine off. am i missing something?
Old 06-14-2010, 12:51 PM
fansy's Avatar
If its in AUTO it will turn off instantly. It needs to be in ON position. One question though, if its in the ON position and you turn off key and open door, does it give that bell sound for you guys? Kinda pointless coz it will automatically turn off anyway.
Old 06-15-2010, 03:50 AM
gcxandrew's Avatar
ohh thats what it is? and yeah i get that bell sound when i turn the car off on ON. i thought it would stay on when its on AUTO like my old maxima did
that explains everything thanks
TLrascal
08-03-2018 11:00 PM
acurajj
09-19-2015 03:47 PM
JnC
09-11-2015 06:06 AM
theinsvnity
09-10-2015 10:22 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: auto off headlights dont work?
