My car is burning oil. Where should I start?
I have an 05, tl, 6sp, 110,000 miles and it's burning oil like crazy, I been putting oil and driving it for like 4 months. My last option is to sell the car, so where should I start ? Should I look for a new engine or just rebuild it completely. I'm leaning more toward rebuilding it. Whats the first thing I should change. I know the 09 tsx manual trannys had oil burning problem but I searched and I could not find any tls that had thus problem.
I found this online of probable causes
Reasons a Car Burns Oil
By Kathryn Roberts, eHow Contributor
An engine that burns oil not only wastes oil but can damage spark plugs, cause the ignition to misfire and eventually affect the catalytic converter. The burning oil can also cause higher emissions, resulting in failed emissions tests due to excess hydrocarbon production. According to New Car Buying Guide, the amount of oil used varies from car to car, and cars with higher usage should consider synthetic oil.
Worn Valve Guides
Over time, the valves wear down the cylindrical chambers, or valve guides, that keep them on track and create a gap in the chambers. According to New Car Buying Guide, this gap allows oil to flow into the combustion chamber, where it then burns. Once the gap becomes too big, the valve seal cannot prevent the oil from making it into the combustion chamber.
Bad Valve Seals
The valve seals prevent the flow of oil into the engine. If the valve seals fail or are broken, cracked, worn down or improperly installed, the oil will be sucked into the engine and cylinders. According to aa1car.com, the compression may not be affected by the leaking oil, but the engine will use a lot more oil than necessary.
Pressurized Oil Pan
If carbon, a byproduct of the engine, builds up in the positive crankcase ventilation (PCV) system, it can clog the system. Generally, the PCV system acts as an exhaust or breathing passage for the engine, but build-up pressurizes the oil pan. This pressure pushes oil into the engine through the fuel delivery system, and the oil burns.
Worn Piston Rings
If the piston rings that seal the engine's combustion chamber wear out, the pressure is sent back down to the oil pan, creating the same end result as when carbon builds up in the PCV system. According to aa1car.com, if the rings are installed upside down, twisted onto the pistons or not staggered correctly, the result will be the same as if they
Worn Valve Guides
Bad Valve Seals
Pressurized Oil Pan
Worn Piston Rings
Pull the plugs a d confirm its burning oil. If it is, troubleshoot based on whether its all cylinders or just one. What's the history, has it ever been run dry?
If it smokes, is it at startup, idle, under load, or Decel which may not be valid due to fuel cut. Remember it can be smoking pretty bad and it will still be hard o see from the drivers seat while moving.
I would properly diagnose before getting a new engine. It doesn't have a CAI, does it?
If you're sure it's burning a substantial amount of oil, my first move would be pull the plugs and take a peek at what they tell you. If only one or two look brutal and the rest look fine, it might be done.
Did you buy it like this and have little to no history? It's not a new issue that suddenly showed up?
I would probably do a compression and or leakdown test while the plugs are out, but that's probably not that critical.
I have never seen blue smoke or smelled anything weird.
Also I found a new mechanic and he told me that I should put 6 quarts of oil, since it's a 6 cylinder. I have put in the recommended amount 4.75 and it burns it, I have put 5 quarts and it still burns it, I have put 6 quarts and it still burns it.
If there was enough pressure to cause this kind of oil burning it would be leaking as well, especially from one of the dynamic seals.
OP, how many quarts do you have to add in a given mileage?
It seems like if it were burning this much oil it would have taken out one or both of the cats of 02s.
I agree but the crankcase is not going to pressure up even if the PCV is blocked. You won't have crossflow but you still have the fresh air side to atmosphere for pressure to escape if the PCV is plugged.
Worn Valve Guides
Bad Valve Seals
Pressurized Oil Pan
Worn Piston Rings
Worn Valve Guides
Bad Valve Seals
Pressurized Oil Pan
Worn Piston Rings
great research!
More than likely gummed oil rings.
It burns about a little more of one quart and a half every 1,500 miles. I don't know why no engine light has come up or no sensors have been damaged,?specially when I drove the car with pretty much no oil. I don't think I got any leaks anywhere cuz when I got the timing belt done at Hamilton the could have seen it.
Plugs first. If you find any oil burners I would do a compression check on all 6. Leakdown would be even better. If there is no evidence of oil burning its time to look really hard for leaks. Also, open the oil fill cap with the engine running, there should be very little vapor or noise in there. I've had bad rings that have a ton of blow by but didn't burn much oil. The oil would hit 300 degrees without going under boost, just regular driving. It did cause a lot of evaporation through the "PCV" system.
What kind of oil are you using. Normally I would try an oil with a very high HTHS and very low NOACK value like Redline but with this much consumption it would probably be a waste of money.
thanks alot for the help, I will come back and give an update on what Ill end up doing.
I think so too, I don't know how nothing happened to the car while I was driving like that. I wonder what caused the car to burn oil, a lady drove the car and she always had kids in the car all the time. I think the car wasn't abused but then againg I don't know.
I use mobil 1, I thought about changing the oil but I don't know which one to go for. I will talk to my mechanic and see what he thinks, make sure there are no leaks anywhere and go from there.
If it uses that much oil, the oil is not the problem nor will it fix the problem. If it's burning, Redline will slow it down but you'll be wasting $10 a quart oil and the additional ZDDP will help end the cats lives slightly quicker. You can try Mobil High Mileage. Not as good as Redline but a little cheaper and it has some good qualities for oil burning cars. I assure you, your mechanic will be of no assistance in deciding on which oil to use. He will probably wan to use a Lucas product.
I'll be very interested to follow this thread. Really surprised that you are loosing oil at that rate and have no external leaks nor smoking nor fouled O2 sensors...
It is a real PITA to have to remember to always add oil, but if that is what it takes, then so be it.
A dry dipstick doesn't necessarily mean zero oil. Being down 1.5 - 2 qts will be enough for the dipstick not to register. That still leaves 2.5-3 qts in the pan. That is not ideal, but it doesn't mean certain damage...
And IHC is correct the mechanic that told you to have 6 qts is a quack, find someone new with Honda/Acura expertise.
That is true...it doesn't mean there is zero oil, key here is how much did you add after you discovered the dry dipstick to get it to full? If you had to add 4 or 5 qts then you've got a serious issue.
One of my previous cars "lost" oil at about this rate with no visible signs. Not a single oil leak, no visible smoke out exhaust, and no issues with the O2 sensors. I just had to be sure to check my oil and add around a quart every 1500-2000 miles. I drove that car like that for an additional 50k+ miles.
Let me know if you figure out what the problem is.have you taking it to any mechanics? What have they said about it ? As soon as I find more info I'll let you know, thanks.
That engine (GM LD9) was known for burning oil is the main difference here. Our engine in our TL is not known for that feature.
Crappy air filters that let in more dirt than normal can't help. The LD9 was known for burning oil as the miles went up, but I found it quite odd that my oil consumption started going up about 10k miles after I had put on the K&N. I do know for sure my oil didn't get nearly as dark and nasty when I pulled the K&N off and went back to the factory airbox and filter the last year I had the car.
This is very high consumption and not normal--something is very wrong. (I have an V-6 Odyssey with 180K using zero oil)
I suggest you'd be better off not trying to guess (no offense but you don't sound like an engine expert), and let a good mechanic look at it. Ask for a simple compression leak-down test--that should tell you what the issue is. Good luck bro.
