My A/C and Heat won't cut on!!!
Please Help! I went to cut my car on last week and noticed that the heat and AC doesnt cut on. I checked the fuses but not the relays. I was told the only way to check them was to buy a new and see if it works. But they can be rather expensive. Since it happed all of a sudden i figgered it had to be something electrical. Help please
me again
oh yeah, im from the previous post. I have a 04 acura tl. The engine was just replaced and has worked well since. I have had a check engine light that just came on too. I took it to Autozone who pulled the code. the easiest code said to add transmission fluid. It took a whole bottle. then the light went out. Two days later the lights back on. Fluid level is ok now.
I'm having the exact same problem with a 2004 TL 3.2. I had been turning heat/a/c system off and on on a pretty regular basis. I went to turn it on one day and the system read like it was on but no air came out. I adjusted the fan speed, switched modes, etc and nothing came out. Everything electronic seems to work other than that. The heated seats, rear defrost, mirror defrost, wipes, radio, navigation, etc. I'm thinking it might be the fan motor. I'm new to this AZ as well.
Yea, I just did this acouple months ago.. is right under the glove box... you will have take out the glove box and kick panel you should see the resistor on the left with a wires coming out .. there two screws holding it in..
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
polish_pat
Sep 25, 2015 12:24 PM
