Moog upper ball joint, is this installed right?quick wheel fitment question too(pics)
About three months ago i noticed some play in my driver side upper ball joint so i replaced it with a moog one since everyone seemed to say they are better. Last week i took off my wheel and noticed the ball joint is not on center. I know that you could adjust the camber by twisting it. But this doesn't seem right, I actually had previously noticed that my driver side wheel seems closer to the front of the wheel wheel then the passenger side but i thought it was my imagination. Is this really how it is supposed to be or did I somehow install it wrong.
Also in the other picture i have a 15mm spacer on my front wheel does that look fine or should i add some negative camber to keep it from rubbing?
You have a "Moog Problem Solver ball joint w/ camber adjustment" on the driver-side, but an OEM (not camber adjustable) ball joint on the passenger side?
Did you get an alignment after installing the ball joint? That's the only way to know if the camber is actually different from side to side.
I don't know how well these type of eccentric ball joints hold their camber setting.
I've only used shops that had the Hunter laser alignment rack/system. I think the newest system is the Hunter HawkEye Elite, but the older ones work just as well. They'll give you a printout of your before/after alignment settings. I found a shop that will allow me to sit in driver's seat while they align it to my settings, which are outside of the OEM limits.
nuldabz
09-03-2015 05:49 PM
