Map Light Bulbs WILL NOT come out
Hi everyone,
I don't know if anyone has had this problem. I recently got LED's for a conversion (map, courtesy, dome, vanity, trunk, license plate, glove box).
No matter what I do, both map light bulbs will not come out. I've tried using rubber gloves, using scotch tape for grip, even using pliers; I really don't want to smash the bulb. I've used a good amount of force....wiggling back and forth and pulling with constant pressure.
Any help guys? Thanks
I have large fingers, which doesn't help >_<
It helps to wiggle them a little while pulling them as I remember. Those bulbs are pretty tough so use a little more force and you'll get them out. The upside is the LEDs are much easier to grip and replace when you get to that point in the future.
You can pop out the whole unit and pull out the lights facing up on a table instead of trying to pull it out overhead. Might get more leverage that way. I used tape and it came out using some force. Whatever you do, dont try to pry it out with a screwdriver or something similar. The bulb will crack! My buddy did that and passed on that bit of advice to me.
Duck tape. Stronger than scotch.
rockyboy
08-04-2024 10:35 AM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
Greengecko
09-16-2015 08:19 PM
