Lunging on Start-up
Old Mar 6, 2012 | 12:24 PM
9632tl's Avatar
Radical Member
Lunging on Start-up
2006 base Tl with automatic.
Last couple times I went to start the car, as soon as the engine starts, the car lunges forward. Almost like it was in gear instead of park. Any idea what could be causing this? It has redline D4 atf in it, and the pressure sensors have been replaced.
It only moves about an inch or so, and its on flay ground.
My last TL did this too, but it was a 96, so nothing about the transmissions would be similar.
Old Mar 6, 2012 | 02:58 PM
guitarplayer16's Avatar
My TL does this too, I think only in the cold.
Then after the quick drive, you turn off your car, and then when it's time to start your car up again, say like when you drop someone off or pick them up, the car starts up smoothly.
Engine mounts maybe?
Old Mar 6, 2012 | 06:12 PM
swishersweep's Avatar
9th Gear
sounds like the motor mounts are bad
Old Mar 6, 2012 | 07:45 PM
TheDingo's Avatar
Resident Dingo
Yes. Motors mounts.
Old Mar 6, 2012 | 09:51 PM
9632tl's Avatar
Radical Member
How would the motor mounts cause this? The car is in park when I start it. It should have no reason to move the car.
Old Mar 7, 2012 | 12:49 AM
9th Gear
the engine have alot of torque so when u start the car the motor mount help support the engine from moving. when the mounts are dead that when the engine have no support, thats y u feel the car moving when u start the car
Old Mar 7, 2012 | 12:58 AM
Ken1997TL's Avatar
Engines still shift in their mounts. After all, it has moving parts in it
Try revving your engine sometime, you'll see it move, even in park.
Now if a mount is bad, it'll exaggerate that movement.
gavriil
Mar 26, 2025 10:16 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
