Low fuel indicator
AZ Community Team
Received 7,771 Likes
Not certain on the '04, but check this (if you want to double, double check that you have a problem):
In the MID go to the Trip Computer screen. You should see Avg MPG, Avg Speed, etc.
Use the V arrow on the steering wheel controls to go to "page 2". That should show
"Range" or "Miles to Empty" or something of the sort.
When "Range"/"Miles to Empty" is ~20-25-30 miles the low fuel indicator should come on.
If you've been through all that and still have the problem, sounds like a sensor issue. For me, that'd be a trip to the dealer.
Okay thank you so much...i currently have 28 miles til empty and the light doesnt isnt on at all. Correct if im wrong but shouldnt the light be on when the key is turned on but not engine running.
Here is a way to test the guages and their lights
Hold trip/reset button
Turn headlights on
Turn ignition switch to ON
Within 5 seconds turn the headlights off, then on, then off
WIthin 5 seconds release the trip/reset button, then push it 3 times
all the lights should blink and the needles sweep.
Turn headlights on
AZ Community Team
No sure.
My "Low Fuel" light trips right about 25 miles Range/To Go. Give it a few miles just in case.
No worries about running out fuel - there is a 3 - 4 gal reserve. From the time the "Range" says "0", you still have ~3 gals and can drive 60 - 75 miles under normal circumstances.
AZ Community Team
joflewbyu2
10-08-2015 11:16 AM
