Loose Driver's Seat
Loose Driver's Seat
My driver's seat (07 Base TL) has a slight rock to it. When I come to a harder than normal stop I feel the seat rock slightly forward. The bottom and the back of the seat move together. Anybody else had this problem? Can the seat be tightened up?
Received 6,470 Likes
Oh man....I've had this same thing happen with my Type S too !!!! I thought I was just nuts, so it's good to hear that someone else has had this happen to them too. I was almost embarrassed to go back to the dealer and say something to them. I'm anxious to see if this is normal or not. Hey, you're not in this boat alone !!
Registered but harmless
Received 1,102 Likes
It sounds like you both have loose seat tracks, which is not normal and is covered by warranty; see the dealer ASAP as a loose seat is no laughing matter.
We had this happen to the front passenger seat on our Odyssey when it was a few months old; the dealer removed the seat, then removed, reattached and lubed the seat tracks.
And welcome to AZ!
And welcome to AZ!
I just set up an appointment for my dealer to look at this on Monday. I'll report back to you and let you know what he said.
Guys...I just got my car back. They checked the drivers seat and found that something WAS wrong with it. They ordered a new track for the seat and it was replaced today. It actually does feel much better and was covered under warranty.
2006 Acura TL
And welcome to AZ!
And welcome to AZ!
try what evnash did, just take a ratchet to each bolt. Place your but on the front edge of the seat, and lean your back against the seatback. If it rocks, then you have a loose bolt in the rear. If it doesnt lean then you have a loose bolt in the front.
2010 CBP SH-AWD
Has anyone had the front passenger seat repair work done? My front passenger seat makes an annoying sound all the time as referenced in the above service bulletin, before I waste my time at the dealership I was wondering if anyone had this repair done and if it made the sound go away, thanks.
Dealer recently replaced my driver seat track assembly under warranty.
No, I did not. I had a clicking sound in my driver's seat. Every time I came to a stop or took off from a dead stop, the seat would click.
GoalieGreg35
I saw a post last year of a closeup diagram showing the bolt assembly and instructions on readjusting the alignment of them. The same post mentions the loose seat is a flagged issue with 3rd gen TLs by Acura. I took the printout to an Acura dealer and was told I was 2 months past warranty and would have to pay for a new track. The entire seat track needs to be replaced when the seat starts to "wiggle". Needless to say I left but am thinking of getting it done anyway because it's enough of a problem that it completely overshadows the otherwise enjoyable driving experience. It's going to cost around $400 Cnd.
rockyboy
12-06-2022 02:29 PM
BoricuaTL
04-08-2016 01:08 PM
