Looking for advice on brake system.
Old Aug 7, 2022 | 03:36 PM
N4ND0L's Avatar
07 TL Type S. Recently changed the brake pads and noticed my brake became very squishy. I fully purged the car three times now and the issue is still concurrent. I also changed the master cylinder and purged it as well but pedal still sinks. I am thinking of just changing the calipers overall but am open to any suggestions on a fix. Thanks.
Old Aug 9, 2022 | 08:59 PM
csmeance's Avatar
First off make sure calipers are installed right with the bleeder being at the TOP of the caliper and not the bottom.
Are you losing any brake fluid? How are you bleeding the brakes?
Old Aug 11, 2022 | 09:30 PM
N4ND0L's Avatar
The brake calipers are installed right and I don't see any leaks under the car. I am bleeding the front brake by pressing three times on the pedal. I think it is either the ABS module or the brake booster. I think it's the ABS module because the pedal is still soft and the ABS light is on. I also think it may be the brake booster because the pedal makes a weird groan wheezing noise when pressed on.
Old Aug 16, 2022 | 10:54 PM
Acura TL Builder's Avatar
When was the last time the brake fluid was changed?
Old Aug 29, 2022 | 06:14 PM
Alvin's Avatar
Is your ABS light on? If it isn't it sounds like you have air in your system. Good time to do an entire brake fluid flush, as that's the only way to ensure you have no air in the system. If you don't know, on the TL you start the bleed from the front left and clockwise as opposed to starting from the back right as on most vehicles.
wmahmud
4G TL Problems & Fixes
41
Jan 3, 2017 11:12 AM
Isabela617
1/2G MDX (2001-2013)
Jul 29, 2014 08:51 PM
Angilletta
Apr 29, 2014 03:14 PM
dubxrossd11
Sep 14, 2011 01:31 AM
