Leaking Interior Problem.
Hello everybody
I would like to know if someone knows what is this ? for what ? and where its coming from?
Im getting crazy
Its located down left side of the driver side.
It has been raining for 2 days and its leaking water inside the car
my car smell as shit already
I went to an A/C specialist, and told me that isnt an A/C component
SO?
any Ideas?
here are the pictures
Im getting crazy
SO?
any Ideas?
I can't see the pics at work, anyone?? But from your description, it's probably your A/C drain hose. If not, then it's your moon roof drain hose. Check to make sure your moon roof drains are not clogged. I think there is one in each corner. Blow some compressed air down the tube to blow it out. You can pour some water into the tube to see if it drains properly, you'll see the water come out under the car. If the tube fills up, it's clogged. Where is the car getting wet on the inside??
I dont know why but I cant insert the pictures
Heres the link of the pictures
there are 4 detailed ones
http://imageshack.us/g/442/leak33.jpg/
But why is the drain tube coming out right there?? That's right over the fuser panel, not good, not good at all. That has to be the drain tube from the moon roof. The tubes running to the front run down the inside the frame of the car, (in the pillars). They drain into the fender and if you pull back the fender lining or look under the car you should see the end of the tube.
Arthur the pipe in the picture is in fact the moon roof water drain. reconnect it to the body where it was. open the moonroof completely and you should be able to shoot a small amount of air from a compressor (or have a shop do it) and that should clear any debris. the drains are on the front left and right corners of the moonroof assembly. it's a good idea to pull some of the headliner down and take a peak from the inside to make sure the hose isn't cracked or disconnected.
IBankMouse
06-13-2020 12:53 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
