AT just took a crap, who sells pressure switch?
#41
i am not getting any code from the obd2 scanner.
if i use the cruise control and accelerate from the steering wheel will that be a way to test if the APP sensor is the problem?
#42
21 Acura RDX Aspec
By any chance, did this problem give u any sign of it forst happening or any possible behavior blurps or studdards (palpitation/hesitations) at all? I have been read most of this thread but no early warning sign mentioned. U just mention all of a sudden on the way to work. The reason for me chiming in and asking is because my AT recently has very light suddle hesitation or pulses in low RPM acceleration... In the range or cruising along of 1200-1500rpm. As mentioned, this range can be met at either accerlating slowly (especially in the morning times) or cruising at approx 40-45mph. Once in a while and randomly it does this act...Any one have any answer? Thanks
#43
well i changed the app sensor and nothing happened....i finally gave up and took it to a specialist...he said if the tranny physically had a problem it would consistently not drive. he took it for a test drive and he said clearly it is an electrical problem. he referred me to a specialist and he did a thorough diagnosis on it. he charges 160$ IF a diagnosis is made. he couldnt find the problem....my last resort is tyring to pull of a recall at acura
#44
21 Acura RDX Aspec
#47
Shudder especially when cold and with low throttle when hot is a classic sign of bad switches. At full throttle little emphasis is put on the switches' inputs so full throttle is usually fine while part throttle gets the shudder.
JayVee (10-21-2011)
#48
21 Acura RDX Aspec
Exactly! ^ It does it when I am first starting to drive for the day or after sitting for hours...Then goes away when I drive low rpm later on like when accelerating from a light or stop... I will be on it asap before any other damages are done.
How much does this service cost from dealer? Or is this something that can be done easily by self? Any recommendations?
#49
They're not?
Read these threads:
https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
#50
ok so check this shit out!!!!
i get my car back from the automotive place...i go down the block to get a burger and then when i wanna leave the car wont start, dead battery. i walk back and he lets me borrow a booster box. car starts. i go pick up my bro and when i park the car...all 3 lights come on and the "D" is blinking on the dash. i turn the car off and it wont turn on a gain i had to boost it again! does this mean the alternator is now dead too???? im so fucked this month! my TL hasnt given me a single issue in the years iv owned it till now!
#52
#53
I only have a few seconds to reply so I don't have time to read your history but if the battery is giving problems, it could easily be the source of all of your problems. Figure out the voltage issues whether it's a battery or alternator or wiring and then worry about the transmission electrical problems which might go away with a new battery/alternator.
I am thinking it is the alternator. on top of everything, my window has recently been getting jammed and yesterday it literally popped out and i pulled it right out of the door!!!! This shit is driving me crazy..thanx for all the help guys
Now how do i test the alternator?
#54
this is becoming ridiculous
i attempt to jump start the car to take it to autozone to test the alternator and battery. I guess my brother crossed the cables on the end of his car and sparks flew all over the place and i disconnected the cables. then i notice the car lights are on even tho i didnt jump it and the car started!!!! i turned it off to see if it still needs a jump to start but it didnt! I then drove to autozone and both my battery and alternator tested fine. I have no idea what the fuck is going on.
#55
takin care of Business in
Received 4,732 Likes
^^^ did he measure the voltage on the alternator and battery ?
how did ur battery test fine when it wasnt working ? the CCA should have been way loww....unless Autozone is 10-15 miles from your home...
#56
because after the cables were crossed and sparks flew all over the place from my negetive battery post, the car didnt need to be jumped after that and from then on when the day b4 it needed a jump for every start....im telling u it was some Frankenstein shit my car is possessed by a demon
#57
^^^ man I feel ur pain...
I would suggest either of 2 options:
1> Take it to the dealer and pay whatever to get it fixed right and with warranty
2> Sell it
I hate suggesting the 2nd option but u cant let a car drain ur wallet....
2> Sell it
#58
#59
did that....the car starting is not an issue anymore (for now at least). Im gonna see if i can get that tranny recall if the previous owner didnt do it already. doubtful and desperate, but i gotta try
mike from annapolis
05-07-2017 08:21 PM
Iakonafuji
09-21-2015 02:39 PM
oyayjoe
09-12-2015 04:40 PM
