Inner tie rod? Ball joint? Noise after replacing outer tie rod and link
So I changed my outer tie rods and links on both front sides because my steering wheel was cracking when turning and I had some play when I pushed it with my hand...the cracking went away and all seemed well for a few days, then it came back and I took tires out to check what could be wrong and heard another noise i'm not too sure where it's from. Seems like 2 metal parts rubbing against each other. Here is a video that shows clearly what i'm talking about. Also could the cracking be from the same source?
Your Friendly Canadian
Received 1,484 Likes
A little hard to tell visually from the video, but I would take a closer look at that inner tie rod end and make sure it's not leaking.
twentythree
4G TL Problems & Fixes
10-29-2021 06:22 PM
tsunamiali
01-02-2016 06:59 PM
Yehokhanan Jackson
1G TL (1996-1998)
11-27-2015 10:48 PM
