I'm Embarrassed! My TL Whistles Through The Streets!
Slowly But Surely
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
I purchased a 2005 TL back in March. Got a great deal because of the high mileage (150K). Purchased a high mileage warranty (5 years or 250K). May have been antsy at the dealership but I swore it was smooth and quiet during the test drive. I live in Poughkeepsie, NY (upstate) so the weather is just now breaking into the "windows down" phase
. Lately, I've noticed a sharp rattle under the hood sometimes idling or often times upon acceleration (between 1-10 mph)
. Through research, I may be able to chalk that up to the heat shield (is that an expensive fix?). Still not absolutely positive though. Beyond that, while at speeds below 40-50 mph, something seems to whine or whistle
. Kinda embarrassing when the car is so dope but people are turning their head, not for the look but for the noise eminating from the hood. What the hell could it be? Is it normal for this type of mileage? My warranty covers powertrain and some electrical (AC, etc.) Are these problems typically costly? Any suggestions are greatly appreciated in advance. Thanx!
P.S. Not mechanically inclined at all. Super scared to fuck anything else up more than what may be. I'm so unhandy .... I tried to swap the license plate lights out with white LEDs and stopped because my clips seemed like they were gonna break. Really not tryna be an enemy to my own whip.
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
![No](https://acurazine.com/forums/images/smilies/no.gif)
![what](https://acurazine.com/forums/images/smilies/what.gif)
Do you get the sound when the throttle is being applied lightly or does it occur all the time at the speeds below 40-50mph? I had a similar problem that occurred in light-throttle situations and the Honda dealer determined it to be a slightly plugged EGR valve/passage. They cleaned it out and problem solved! The sound coming from my car wasn't really a whistle, though. To me it sounded more like a metallic rattling sound. This could be a possibility considering your TL has so many miles and the EGR could be dirty by now.
Slowly But Surely
Slowly But Surely
I saw threads about the auto tensioner assembly. I was assuming that created the constant whining sound. Wasn't sure though. You changed it yourself or the dealer? Expensive? Difficult?
Slowly But Surely
My high mileage warranty is through another company. My dealer said that he didn't think Acura would offer me one or it would be hella expensive. Did some research and picked out a reputable one with a good BBB rating. Only powertrain and some electrical though. Doubt if this problem fits the criteria, but I'll check into it once I get the problem singled out.
Slowly But Surely
i am having the exact same problems! As soon as i pull out from a stop the very beginning of my acceleration it rattles and then goes fine than it starts whistling/wining from the back rite?
I was charged $105 (1.20 hours of labor) to remove the EGR and clean the valve and passage. I go to the Honda dealer because it is much closer (Acura dealer over an hour away) and I can drop my car off and they will give me a ride to and from work.
Slowly But Surely
It sounds as if we are experiencing the same problem but I'm not sure if it's coming from the back. It seems as if it's coming from under the hood.
Slowly But Surely
Thanx for the info!
DER NEUE ^
I'll take a shot at it. You might need a new drive (serpentine) belt auto-tensioner and may be a new belt as well. If you get a metallic rattle sound at idle, does the rattle increase when the AC kicks in? That's a sign of a bad tensioner. When you twist the belt, do the edges or inside grooves look cracked, torn or otherwise damaged? If so, you need a new belt.
Goodyear makes a quality tensioner kit that includes both the tensioner assembly with pulleys (idle/tension) and the drive belt. It's their Gatorback series, K49349A- can be had for about $75 shipped. GL!
DerrickW
11-15-2015 05:52 PM
