I see another tranny failure in my future..
RPM needle started jumping without any acceleration. Pulled over and tried to move the car but it wouldn't budge. Car jerked a little as if the ebrake was on. Let the car sit for 15 minutes and afterwards drove fine. Able to make it home. Had to drive 3 hours since I was in the middle of the desert at about 4am. When I check the ATF fluid level the fluid gave off a strong burnt smell. Is this the start of the ending? Also keep an out for my part out thread.
Try to change your tranny fluid with the new oem fluid and see if it helps, it has helped a lot of my friends when it comes to tranny problems.......
User name ELPESADO had same tranny issue couple years back,he go it rebuilt
So just to clarifly I am on a rebuilt tranny. Its still under warranty. The RPM needle spiked while on a steep incline. I didn't even know there was a new OEM fluid. Is it supposed to be better than the old Z1?
The new fluid (DW1) is supposed to be much better than the old Z1. I'd take your car ASAP to acura and have them look at it, esp if it's under warranty!
The tranny went at 58,000 and they wouldn't honor the powertrain warranty because of the supercharger. I asked about swapping out the fluid and Acura told me that would do more damage at this point. Since its rebuilt I have it covered under warrantly at a shop in the Bay Area. How does the DW1 fluid compare to some of the aftermarket fluids like Amsoil or Redline?
The new oem fluid does miracles literally...!...car runs smoother instantly,plenty of friends of mines have switched and has eliminated slipping.....I've used it myself also on my old 05tl.......
Change it!...don't put anything else,even if they valid your warranty and fix it,make sure you put only oem fluid
I use to have an accord that use to slip like crazy on those universal ATF fluids...changed it to oem before it was to late....
Anyway ended up paying to get it rebuilt out of pocket.
I had good success back in the day by taking everything off my Civic, and bringing it back to the dealer.
Hmmm so what's this sw1 y'all speak of? Was gonna do the 3x3 change with redline but lots of you vouch dw1. Haven't heard of it. Any links to buying it and extra details? I have an
05 tl with 162k miles trying to make the granny last. Sometimes she stalls on a shift or it'll b extra hard
Again, they have to PROVE it. they can say whatever, but they have to actually PROVE it. They can't prove it becuase they know tthat trans failures are design related and not power related. The gears and clutches in the 5at are very good but when they are not properly lubricated, they overheat and fail.
Afraid not, they can just void the warranty, which in this case was the correct thing to do. The owner modified the vehicle from stock form by putting on a SC. Big 3 (Ford, GM & Dodge) have been voiding warranties for years on many diesel pick-up's due to owners adding HP/torque upgrades.
I understand what you're saying but back when I bought the car, Acura of Las Vegas on W. Sahara sold and installed superchargers. The ONLY reason I didn't get it installed there was because of their labor rate. But seems a little silly that they would sell and install your SC and then void your warranty because of it.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Pham Alvan
Mar 16, 2016 09:17 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
