how to get rid of brakes squeaking?
Old Aug 23, 2010 | 03:05 PM
cust0mx's Avatar
Went to Les Schwab last Friday and said that the pads and rotors look fine, but my brakes still squeak. Any suggestions on how to get rid of it? Do I need to put some grease on the pads?
Old Aug 23, 2010 | 03:10 PM
Turbonut's Avatar
Squeal when slowing, press harder and no noise?
Put anti-squeal lube on the part that meets the piston(s).
Old Aug 24, 2010 | 12:58 PM
01tl4tl's Avatar
take them apart- clean the sliders and relube with synthetic caliper grease
lube the back of the pads where the contact marks from the pistons hit
lube anywhere that has to move against each other
any ridge on the rotors?
drive it slow a lot and drag the brakes to stop?
ever use the brakes in a more aggressive manner- they like that!
Brembo fronts?
Old Aug 24, 2010 | 04:25 PM
KN_TL's Avatar
I did a brake job on my Pilot and it's got the squeal's too. It is getting better but I am going to do as 01tl4tl says and also get the stuff Turbonut mentions. It is embarrassing for sure.
Old Aug 24, 2010 | 05:14 PM
Turbonut's Avatar
Most brake noise under light braking is that the pads actually move slightly inside the caliper and this movement creates a squealing noise, metal to metal as the pads or shims move against the piston(s). Under hard braking no noise as the piston pressure keeps the pads steady inside the caliper.
Old Aug 25, 2010 | 01:14 AM
PowerCommander's Avatar
When I first had my TL I could have gotten it lemoned for this same brake squeling issue. Since I liked the car so much I just kept taking a drive with my gf to the dealers since I liked driving around different loaners while they work on my car. Plus I love their reactions on their faces when my girl steps out of my car hahahha. I tell her to dress sexier than normal and I get top notch service. hahahah. But yes it's the break pads. This is a known issue with TL's. Took me 4 or 5 trips for them to finaly get it worked up. Took that many because they thought they could just lube it but won't work for long. Besides lubing breaks? Common sense tells me not to why lube something that was engineered to grip? Finaly since it was such a big issue with TL's they have created a new brake pad that would eliminate the squaling once and for all. Too bad I had to keep returning for the same issue over and over cause they thought if I drove it enough it will go away. Wrong! New brake pads from the dealer got it solved. Just took them long enough to manufacture a new type for our ride.
Old Aug 25, 2010 | 06:13 AM
Turbonut's Avatar
Well, I certaily hope people do have some common sense and no one ever decides to lube the pad material!!!!!!
Old Aug 25, 2010 | 06:48 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
My friend did that once.
Old Aug 25, 2010 | 07:05 AM
Turbonut's Avatar
Yup, have seen it done before. Some first timers just think as the brakes are making a noise, lube the pads and it will be good. They just aren't knowledgeable, but learn quickly.
Side bar-Many years ago there was a fellow in his 20’s in the Saint Barnabas burn center as he decided to start a fire in his fireplace by dousing the wood with gasoline first, then leaving the open container next to the fire box. He said he had no idea that an explosion could happen.
Common sense for some, but others just don't know.
Old Nov 29, 2010 | 06:17 PM
jhumbo's Avatar
08 MDX, 04 TL (sold)
I have brake squeal under light/medium braking. It goes away when braking harder. I have been to the brake shop numerous times and they say there's nothing wrong and that it is a "normal" noise. They put anti-squeal lube and it went away for a couple weeks, but then the noise returned. A good majority of my driving is highway and I don't brake hard very often.
I wonder if this is what is going on in my case. How would I know? Wouldn't the brake shop know to check this out?
What are these "new" pads that PowerCommander is talking about? Perhaps this will solve my noise issues?
Old Nov 29, 2010 | 06:57 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Normally, pads do make noise over time. Rotors rust blistering will cause pads to make noise. If these are aftermarket pads it's usually due to the compound material used to make the pad. For OEM pads making noise again the above statement still stands or a pad that has becomed chattered due to warped or blisted rotors. Usually changing the pads does the trick, depending on your mileage they may cut the rotors as part of doing the pads.
Old Dec 1, 2010 | 05:27 PM
jhumbo's Avatar
The noise seems too loud to me to be normal. I went 120,000 miles without brake noise (or at least it wasn't loud enough for me to be constantly noticing), and the noise has only been there for the past 10,000 miles since I got new aftermarket pads and rotors one of those big chain brake shop places. Maybe that was a mistake.
Old Dec 1, 2010 | 05:42 PM
qurious9ss's Avatar
I had a bad squeek on the rears. There was about 70% pad left so took them apart and cleaned them and relubed but still kept squeeking. Replaced them with some Akebeno ceramics and problem was solved.
Old Dec 23, 2010 | 02:03 PM
Steve 21's Avatar
My pads have been squeaking loud at soft/medium braking also. Went to my buddies shop today to look at it and he thinks the reason its squeaking is because the pad is sitting higher then the rotor so the rotor is almost like slicing into the pad. Have any of you guys looked at that, and is that maybe something happening? I have a type-s and are these problems common for base or type-s or both? Well we just put it back together and he said to check with Acura if its a common problem. I haven't made it there yet but came across this thread and had 2 questions,
Did any of those suggestions stop the squeaking for you guys?
Those new brake pads, did they work?
Old Dec 23, 2010 | 07:01 PM
callahan's Avatar
most people just go cheap on pads, there cheap for a reason lol. aka they will probably make noise.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
