How to disable F/I when performing a compression test?
RWD convert
What is the correct fuse to pull in order to disable the fuel injection on a 2007 TL when performing a compression test? I was just wondering, since on my wrx i had to remove the fuel pump relay before performing one.
Underhood main fuses- check the listings- Fuel Pump
No fuel= no problem
The ignition is what I would be concerned with- not like you can ground a plug wire here.
Check for a main fuse for it too
No fuel= no problem
keep the injectors plugged in and keep the car at WOT this will give the the most accurate reading.
if its just air in the cumbustion chamber there is nothing heavy to try and bust the seals, so a little gas, and the TB open to let escaping air out, will give you best results.
just remember to have all the plugs disconnected!!
with our hi energy COILS on the plugs- I think we need a real experts opine on this one
It cannot be a good safe idea to just unplug the coils like that- stopping th eoutput of spark seems reasonable
PM sent to guru
PM sent to guru
joflewbyu2
10-08-2015 11:16 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
