How can I fix the paint scratch?
Try a cleaner wax. If that does not work try some rubbing compound followed with wax. Be careful with the compound though. It is abrasive and can wear away layers of your paint of your are too aggresive.
If it's deep, then you'll have to repaint the area. Can you feel the scratch with your fingernail? Otherwise, you might be able to buff it out by hand with a product like Meguires Scratch-X or use a PC with a polishing compound. Be sure to wax afterwards.
Clearcoat Scuff
From the pics it looks like these are just clearcoat scuffs and most likely can be buffed out with a fine buffing compound. But like what he said above, if you can catch them with your finger nail then you will have to wetsand the area with 1000+ sandpaper and at least respray the clear.
-Mike
-Mike
