How bad is this?
How bad is this?
Was under my car changing my oil and I noticed this crevice near this bolt how bad is it and what exactly is this piece called , also I have a power steering leak somewhere in trying to find do you think it would be the fluid you see on the metal in the back?
The component in the pic called engine cradle aka subframe, its looks bad you should look for a replacement. This is why you should check and replace the LCA bushing once they starting to tear.
daaaaaaamn thats unfortunate af I just looked at the price looking at at least 600 into this wow, what about the fluid do you think its from my power steering pump im still trying to locate the source of it Im hoping I dont need a new pump especially with this issue coming up, how do you think this happend?
So I'm not going to drive my car for a while my front compliance bushing worn out its only this side that looks like this if I change it I should be ok in the long run right?
The DVD-A Script Guy
No one will spot weld that because the reliability is too great, your LCA is totally shot. I WOULD REPLACE BOTH LCA
as far as the PS leak, check the high pressure side lead down toward the rack. BTW how do you its the PS leak?
cabanalane
Home & Garden
168
08-23-2018 06:37 AM
lojik
07-04-2016 07:01 PM
