hid flickering
Old 01-16-2007 | 11:00 AM
imrantl's Avatar
hid flickering
i installed the kaixen 6500k hid replacement bulbs and the fogs with the hid foglight kit. now when i drive after, after 2 minutes my right side headlight flickers and than turns off. does anyone know what the cause of this can be
Old 01-16-2007 | 11:46 AM
K-Shawn's Avatar
VS#03
I had the same problem when I upgraded the bulbs to 6000k and the service dept said it was the aftermaket bulbs that burns out the igniter and the ballaster, also it always starts with the driver side bulb. The service dept wanted to charge me $1200 to change the bulb, ballaster, & igniter but the only thing that saved me was that they where the ones that installed the bulbs, so it was covered under warranty. I think you have to get a voltage regulator to regulate the voltage if you're going to upgrade the bulbs.
Good Luck
Kevin
Old 01-21-2007 | 10:06 AM
blaze6257's Avatar
Its probably being caused by the aftermarket bulb, the voltage/wattage ratings are never the same as OEM and can cause problems, or its a grounding issue.
MilanoRedDashR
10-08-2015 10:30 AM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
2Quik
09-23-2015 01:03 PM
Quick Reply: hid flickering
