Help! Where is the auto transmission fill??
I've searched the forums. I have the service manual. Can't tell from the diagram where it is. I've located the drain plug. The fill plug eludes me. Is it on the top? Do I have to remove the air cleaner to see it?
It doesn't look like a plug it is a 17mm bolt on top of the transmission. Be prepared it is usually very tight. You don't have to remove anything to see it.
Thanks, found it. You were right it is tight.
