HELP solenoid purge valve
04 tl
i had the check engine light on and took my car to sussma acura in jenkintown, they said i need a new solenoid purge valve and dust filter that goes to the canister. does anyone knows of a forum on here on help with the removal of these parts. thanks.
acura master tech
most likly its the purge valve . its the sensor/ valve bolted to the intake next to the throttle.
it has the rubber gromits and 2 10mm bolts. its called the purge control soleniod or pcs valve
