HELP! Smoke (and fire?) from engine bay!
Ok so i was driving in the hot california sun and for some reason smoke started smelling from the engine.
I pulled over, and checked the coolant and oil and they were ok and there was plenty in the reservoir. I restarted the car and drove torwards home and the smoke faintly continued. I then parked at home left it running so i can check it.
Suddenly a faint flame came from this area out of nowhere, it then died out, and then smoke came out of the area every few moments.
I am not getting any check engine lights, increases in temperature, or anything notifying me of the problem. Any help?
Thanks!
Thanks!
Power steering hose melt through or leak. Don't run the engine any more. There have been full fledged fires that destroyed the car caused by this.
There is a recall for 2004-2008 TLs to provide a new hose with a heat shield on it. Do you know if the recall was done on your car? What year is your TL?
To view the TSB, go to this link, follow the instructions EXACTLY, then click on the link for TSB 08-16:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Are you the original owner? You can find out if the recall has been done by calling your dealer and giving them the VIN.
Also, you can register the car at myacura.com and the site will tell you what recalls have been applied to the car.
The black hose you see in the picture is the PS hose. It dips behind the engine and is likely being melted by the rear cat or back side of the engine exhaust manifold.
AZ Community Team
Received 7,771 Likes
Rule #1 - Make sure the safety recalls on your car have been done.
That is a good practice for anyone buying any car.
It's very easy to call dealer service, give them the VIN and ask them to check for open recalls - even before you buy the car.
I called the dealer the same week i bought the car and was hung up on twice, so i put it aside. Which i do regret
HOWELLiNC
09-18-2015 11:12 PM
