Help please?! Navigation LED's?
Old Oct 25, 2016 | 08:13 PM
Poison Lyrics's Avatar
5th Gear
I have a 05 Acura TL and so my climate control leds we're out so I replaced them I ended up replacing all of them and they worked flawelessy! But then the next day one of them went out maybe because of being loose so I opened it up and tried adjusting it and also the car was on with the headlights on as I turned the led all of them went out. I then turned the car off for awhile but when I turn the headlights on the clitmate control leds come on for a few seconds but are very dim then die out. Please help anyone?
Old Oct 25, 2016 | 09:35 PM
peter6's Avatar
Remove the LED that you inserted last (one that might caused the problem). Also there might be a fuse. I think you might shorted it out (if I understood correctly, lights were on when you inserted the led) .
According to manual from 2007-2008, look for fuse #4
Old Oct 25, 2016 | 10:01 PM
5th Gear
Thanks for you reply! I'll try this when I get out of school tomorrow fingers crossed everything works again
Old Oct 26, 2016 | 03:28 PM
5th Gear
Okay so i checked the fuses near the pedals and under the hood they all seem fine. the leds turn on for a few seconds when i switch my headlights on but they are super dim and die out? IDK why this is happening and suggestions?
Old Oct 26, 2016 | 03:30 PM
did you get t3 neo wedges? one of them is the culprit and shorting out.. take em out one by one and test
Old Oct 26, 2016 | 03:35 PM
5th Gear
Yes. They are t3 neo wedges. ill test all of them and get back to you...
Old Oct 26, 2016 | 07:01 PM
5th Gear
Confused
They come on but aren't as bright as they are suppose to be they are slot dimmer
Okay so they are suppose to be this bright these are the less I replaced in the speedometers outer assembly
And like a few mins later they fade out But I did take them all out and test each of them and hey work fine but when I put them back in they work but they are dimmer and then they fade out. I checked all the fuses but still nothing the fuses are all good
gavriil
Apr 1, 2026 12:45 PM
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
Nov 7, 2016 03:31 PM
Moonlight2002
Jun 22, 2016 04:44 PM
Michael Hinchey
Apr 20, 2016 08:13 PM
neuronbob
3G RLX (2013+)
Nov 27, 2014 11:58 AM
