Help! No dashboard/power but car still running
Hi this is my first time posting ....
recently my 2005 Acura TL battery died and car wouldn't start i tried boosting it twice and it started but then it just died while in my parking spot as i tried to let it idle to charge the battery...
so i went to canadian tire and bought a new battery put it in the car and it starts just fine the only problem is the dashboard has no power, the moonroof/windows have no power, the radio has no power, and the windshield wipers won't work either or the turn signals
This is troubling me a lot as my car is my only means of transportation and i can still drive the car but i really don't want to as it is a huge risk driving in winter with no windshield wipers or turn signals
Other than this the car is running fine the headlights work, and even the hazard lights and interior lights in the car work
but nothing else.???? CAN ANYONE HELP ME TOWARDS A SOLUTION
Check the fuses.
Did you pick up the Motomaster Eliminator Ultra? Good battery.
i tried to check the fuses but i couldn't pull any of them out at the moment.... i was having trouble I'm not that good with cars but my friend told me i should go to the Acura Dealership tomorrow and they will restart the cars computer? ill let you know if that fixes it
The problem is not the computer. Check the fuses. Be aware it could be a 'main' fuse if the car has independent power for the ECU, I'm not familiar with the electrical on your model. If you can't pull a fuse you might want to take it to the dealer.
Are you sure you didn't try and jump it backwards? That can total a car under some conditions, although its partially protected against it, although it does mean blown fuse(s).
- IP lights and gauges
- Turn signals and 4-way hazards
- Windows and sunroof
- Climate control system (with fuse blown, it only blew hot air)
That's just what I'd noticed so far... there may have been other inop systems! Anyhow, fuse 7 only for me -- 21 was not blown.
The following 2 users liked this post by TLin05:
NBP04TL4ME (03-10-2015),
Will Y. (03-10-2015)
Stay Out Of the Left Lane
Received 1,236 Likes
Besides way too much, I wonder what a dealer would charge to replace the #7 fuse
so $198 plus taxes. Oh and they'll do a free multi-point inspection all of a sudden you have a oil leak and your transmission shifts funny and a bunch of CELs will pop up.
In other words, do that shit yourself.
I'm going to guess an hour of labor so $130-150 and about $7-8 for the fuse.
B-O-H-I-C-A
B-O-H-I-C-A
For the possible benefit of others, will answer my own question: YES. In my case, fuse number 7 (interior panel above the hood release) was the culprit. Replacing it restored:
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
