AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL Problems & Fixes (https://acurazine.com/forums/3g-tl-problems-fixes-114/)
-   -   Help-engine leak (https://acurazine.com/forums/3g-tl-problems-fixes-114/help-engine-leak-939808/)
siriusalpha13 Dec 14, 2015 08:56 AM
Help-engine leak
so i have an oil leak in this picture and not sure what it is called, any help would be nice
https://cimg0.ibsrv.net/gimg/acurazi...9c4af9288d.jpg
its leaking around the gasket, any help would be appreciated
siriusalpha13 Dec 14, 2015 08:58 AM
near the top two bolts is where its leaking, smells really bad after a long drive, any help would be nice
flyromeo3 Dec 14, 2015 09:17 AM
valve cover grommets.
Beck Arnley 039 6520 Valve Cover Grommet | eBay
Oh Sickest TL Dec 14, 2015 09:41 AM
youll prob have to take the valve cover off and replace the valve cover gaskets as well
siriusalpha13 Dec 15, 2015 04:42 AM
what is this part called? this is where its leaking at, not the grommets
https://cimg8.ibsrv.net/gimg/acurazi...6a83ed209c.jpg
Oh Sickest TL Dec 15, 2015 09:19 AM
that is your coil pack.....under that... just looks like a metal bracket holding the front cat in place?
thoiboi Dec 15, 2015 09:30 AM
Potentially leaking from valve cover/spark plug grommets onto the cat which burns (hence the smell you're getting)
Oh Sickest TL Dec 15, 2015 09:37 AM
Originally Posted by thoiboi (Post 15634926)
potentially leaking from valve cover/spark plug grommets onto the cat which burns (hence the smell you're getting)
bingo
siriusalpha13 Dec 16, 2015 04:11 AM
ok so replace gasket/grommets and problem solved?
nfnsquared Dec 16, 2015 09:43 AM
check the plug first, but otherwise, yes to the grommet/s. If you have the valve covers off to replace the grommet/s, might as well replace the valve cover gasket/s. And as long as your there, check your valve clearance if you feel up to it.
One note: be very careful when torqueing the valve cover bolts. The spec is only 8.7 ft-lbs. The bolts have stops on them, if you hit the stop before reaching 8.7, stop. If you don't have a torque wrench that reads that low, I would only use a 1/4" ratchet to avoid over-torqueing.
© 2026 MH Sub I, LLC dba Internet Brands
