Help with accord transmission swap
Hello I’m new to the forum and hopefully someone can help
I picked up a 06 Acura TL with a bad transmission. I read a lot of posts on here about swapping in a 06-07 accord transmission so I picked one up and started doing it last weekend.
The only trouble I’m having is I can’t find any wiring harness that is different ? The two short harnesses that are on the drivers side are exactly the same .. from what I read I though one of these needed to be changed to the TL harness ?
i also noticed that the atf warmer is exactly the same . I thought there was some difference between the 2 ?
Any help would be great
So I used the wiring harness from the accord. Everything plugged in and I’ve put about 300 miles on it. So far so good everything seems to be fine . Not sure why everything I read says it wont work
jkilla369
04-23-2023 12:22 PM
core4874
08-26-2015 10:53 PM
