AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL Problems & Fixes (https://acurazine.com/forums/3g-tl-problems-fixes-114/)
-   -   Help (https://acurazine.com/forums/3g-tl-problems-fixes-114/help-909501/)
allaces Apr 20, 2014 08:28 AM
Help
Coming back from road trip. Engine light and gear indicator lights blinking car running rough...any opinions helpful.
ez12a Apr 20, 2014 11:15 AM
getting the codes read would probably be the best course of action.
Turbonut Apr 20, 2014 12:28 PM
Hear any strange sound?
YeuEmMaiMai Apr 20, 2014 12:34 PM
+1 for code read blinking [D5] light = problem with trans and you will need a scanner capable of reading those codes
allaces Apr 21, 2014 01:35 PM
Had a short. Bad ignition coil but here's the kicker. Went to remove bad coil and tube that goes into plug was melted...how the hell am I gonna get melted plastic out of there???
Turbonut Apr 22, 2014 06:12 AM
Why I asked if any strange noise is because the problem can be caused by a spark plug that has backed out and the heat has caused the coil pack to melt, esp. #5 cylinder.
There's also been problems with a melted coil(s) some due to the PCM that has had water intrusion from a clogged condensate drain causing the coil to overheat.
Some have taken hours to clean out the head, others have had to remove/replace the head.
allaces Apr 22, 2014 10:08 AM
turbonut you hit on the nose. shop is picking it up today filed claim with my warranty.
© 2026 MH Sub I, LLC dba Internet Brands
