Help
Old Apr 20, 2014 | 08:28 AM
allaces's Avatar
Help
Coming back from road trip. Engine light and gear indicator lights blinking car running rough...any opinions helpful.
Old Apr 20, 2014 | 11:15 AM
ez12a's Avatar
the overexplainer
getting the codes read would probably be the best course of action.
Old Apr 20, 2014 | 12:28 PM
Turbonut's Avatar
Hear any strange sound?
Old Apr 20, 2014 | 12:34 PM
YeuEmMaiMai's Avatar
+1 for code read blinking [D5] light = problem with trans and you will need a scanner capable of reading those codes
Old Apr 21, 2014 | 01:35 PM
allaces's Avatar
Had a short. Bad ignition coil but here's the kicker. Went to remove bad coil and tube that goes into plug was melted...how the hell am I gonna get melted plastic out of there???
Old Apr 22, 2014 | 06:12 AM
Turbonut's Avatar
Why I asked if any strange noise is because the problem can be caused by a spark plug that has backed out and the heat has caused the coil pack to melt, esp. #5 cylinder.
There's also been problems with a melted coil(s) some due to the PCM that has had water intrusion from a clogged condensate drain causing the coil to overheat.
Some have taken hours to clean out the head, others have had to remove/replace the head.
Old Apr 22, 2014 | 10:08 AM
allaces's Avatar
turbonut you hit on the nose. shop is picking it up today filed claim with my warranty.
