Heat to Floor
Heat to Floor
I can't seem to get enough heat flowing to the floor no matter which mode or how high I set the temp.
I do feel some warm air coming through a vent on the driver side, but my feet are always cold.
Is there a lever to open up vents to the floor?
No lever that I know of.
If you haven't already, try to take the temp up to, say 83 - 85, set the MODE to the floor and manually set the fan speed to med - high. IOW - put it in as much manual operation as possible.
If that doesn't work .... Dealer under warranty.
Thanks, I tried that
There is heat coming out one vent, but it seems that there are cold pockets around the pedals. Maybe the car isn't well insulated.
Just wondering if anybody else had these issues.
Check the owners manual for operating tips and diagram of airflow combinations.
There may be a door stuck somewhere
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
I've noticed this too. Granted it is really cold out, but I am finding that there is a cold pocket even with the heat running to the floor.
JDM96specCTR
10-17-2015 01:06 PM
