Headlight problems
Headlight problems
My 06 TLs headlight seems to be going out? when i turn them on they look fine for a few seconds then the light dims to a pink color? a tech where my wife works (local Honda dealer) said that it might be the ballaster
Any ideas whats the fix? i have an extended warranty but Acura told my wife it only covers certain components?
Pink light means that your bulb has reached the end of it's light. To confirm you can swap the bulb from the other side over and see if it's pink and vice versa.
If you do end up needing a new bulb, your best bet is to buy a good QUALITY set of bulbs (replace in pairs) such as the OSRAM CBI bulbs or the Philips 85122+ bulbs.
Thanks guys for the advice!
Land of 10,000 lakes
Definitely the bulb "pink eye" is your warning. If it were a ballast problem your lights wouldn't turn on at all.
http://www.theretrofitsource.com/index.php?cPath=27
i followed a diy here and borrowed a t20 torx bit from my friend....and when i got to my headlights, it wasnt t20!! i had to improvise and use a small flathead to get the screw out, afterwards i used a regular philips screw to replace it.
Got it done yesterday what a pia! just to replace a bulb that is probably the worst disappointment ive had in the 2 years ive owned the car? Other then that love the car
tman570
06-11-2019 07:56 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
