Headlight housing has yellowish hue?
Below are pictures of my front left headlamp. If you look closely you can see this "yellowish, wavy" hue. I recently noticed this on both of the headlamp casing/housings. It seems to be on the outside of the plastic casing. Any suggestions on how to get rid of it and or what it is? It's an 06 and I've had it since then, probably due to weather wear and tear?
https://acurazine.com/forums/picture...ictureid=44612
https://acurazine.com/forums/picture...ictureid=44611
Did you just recently buy your TL?
The only cause I would know is that your headlights were hazy, then someone used a headlight polish on it to remove the haze, but didn't put much pressure on the border of the headlights, due to the fear of getting polish on the paint.
How would I know?
Well, same thing is on mine, except mine is barely noticeable.
The solution?
Get some headlight polish, and work it in around the edges.
Cheers!
How would I know?
The solution?
Cheers!
iWhine S/C 6MT TL
Buy this
jkamboj (06-26-2011)
Thanks for the help. I used a kit and it did the trick! Heres a link showing the before and after:
https://acurazine.com/forums/3g-tl-problems-fixes-114/headlight-yellow-hue-fixed-824476/
