Headlight help!
Old 08-22-2010 | 05:39 PM
LwPTL1223's Avatar
ACTASY
Headlight help!
So i noticed my headlight didnt come on....checked the fuses and all were good....so i switched them out cuz it was the left headlight that was out so i replaced the right headlight fuse with the left fuse and it came on.....turned my car off locked it came back outside again and wasnt workin.....anyone kno what could be the problem hear.....also i notice wen im in my car and i turn the lights on i hear my amp for my subwoofer like thump....very weird
Old 08-22-2010 | 05:48 PM
dwb993's Avatar
Did the second fuse blow, too? Maybe a short somewhere.
Also, get your battery checked, especially if its a crappy Acura battery.
Old 08-22-2010 | 10:05 PM
LwPTL1223's Avatar
ACTASY
what do mean did the second fuse blow? and how would u fix a short?
Old 08-22-2010 | 10:36 PM
dwb993's Avatar
If you swapped the fuses and it worked for a while, then stopped, did any of the fuses blow? If not, I would say you have a loose connection or a short in the system somewhere. They can be a bitch to isolate. If you know anyone familiar with car electrical, have them take a look at it. You will most likely need a multimeter to check all of the connections.
Old 08-22-2010 | 11:19 PM
LwPTL1223's Avatar
ACTASY
Think their could be a bad connection at the headlight?...and can i do this without removing the whole front bumper? because i dont think its the bulb because it worked then stopped
Old 08-22-2010 | 11:33 PM
dwb993's Avatar
You may be able to get your hand back there, but be careful---those HID ballasts can generate a lot of voltage. To really check all the connections, you should remove the bumper cover for better access.
Old 08-22-2010 | 11:45 PM
LwPTL1223's Avatar
ACTASY
okay thanks you've been a big help.....the guy who is wiring my dads street rod is gonna take a look at it tomorrow ill let you kno if we have any success thanks alot!
hashbrown
02-18-2022 12:20 PM
Mr.Tea
10-02-2015 11:32 PM
MilanoRedDashR
09-27-2015 11:15 PM
h22lude
09-27-2015 07:22 PM
AmplifiedDetails
09-24-2015 03:55 PM
Quick Reply: Headlight help!
