headlight help!
headlight help!
i recently purchased a set of blacked out headlights from a fellow member and while the install i noticed that my ballast is to big for the brace any way to safely rig the ballast onto the brace?? thanks for the help!
sounds like you bought a set of 06 blacked lights, and you have an 04 or 05
whats the problem? the two holes on the ballast brace dont line up to the two holes on the car frame? if so, you can bend that metal brace (carefully)..
sorry i kinda worded it wrong....the brace and ballast dont fit properly on the headlight itself...i dont know if there is a way to safely keep the ballast and brace on it or not...like the holes on the brace and ballast dont match up with the holes on the headlight
Your thread is being moved from the Performance Parts & Modifications subforum into the Problem & Fixes subforum. Please read the rules before posting in the Performance subforum. The rules can be found here: https://acurazine.com/forums/announc...nouncementid=7
AmplifiedDetails
09-24-2015 02:55 PM
