Glovebox alignment
Glovebox alignment
I've read the 3G garage on how to fix a glovebox rattle,but is there a fix to re-align the box so that the part closer to the door is the same as the side next to the console? It doesn't need to be moved much,but it sure would look a lot better than it is now. Thanks in advance.
glove box alignment
If you have a 05 or06 tl you can try putting spacers behind the two screws in the glove box housing , also try elongating screw holes on right side hinge. Last to close the gap try pushing metal door latch up a little bit with the handle side of a hammer. mine looks pretty good now but not perfect. Take your time and you will be satisfied.
7th Gear
Assuming your TL is still under warranty, have the dealer do the adjustment. Dealer did a great job on mine. Don't know how they fixed it, but it is perfectly aligned now.
emailnatec
29
09-28-2018 04:27 PM
Zonian22
11-14-2015 01:20 PM
