Gear wont shift....
Gear wont shift....
Hey
I just bought a 2004 acura tl & my gears wont switch & my horn wont work. I changed the fuse because somebody told me that the horn & the gear switch are linked & they both worked fo 2 days (MAX) & then they eventually died. I have switched the fuse 5 times this week alone does anybody know whats going on?
Do you mean the car will not move from park to other gears? If yes, it is a fuse. I would try to see why the fuse blew. Is you car under warranty? If so, take it to the dealer to see what's up. If not, all i can suggest is that you take the car apart and look for shorts in the wiring and check all the grounding points.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
guyvelella
09-30-2015 11:02 PM
AcuraKidd
09-26-2015 04:10 PM
