FUUUU-> Trans just went out... Fun
I'm driving along in the city and I'm going to make a left turn. Traffic clears and I press on the gas to go forward and the car turns and refuses to go over 20. I let off and get back on the gas again thinking my thinking its the APP sensor acting up.
Now the car violently jerks, smokes come from the tail pipe and its freely revving. I stop the car, put it in drive, restart it and it's in limp mode. I limped it to the parking lot where I'm waiting on a Tow. It's fun typing on Azine from a phone![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
What irks me is that I've done the fluid changes (with Z1 though) religiously almost every other oil change and as well the car gave no indication of it (no slipping, etc). I'm just hoping it's electrical but may be SOL since the D light isn't flashing and there's no CEL light on.
Fun way to start the weekend... But I do have to applaud my dealer and SA, called them and they said that they'd have a loaner ready and a tech ready to figure it out as soon as I come in! Props to Courtesy Acura and Angela Disco in Service!
Maybe this is a sign, 105K service in less than 500 miles...
My Garage not
1 Post
this is bad news since you did preventative maintenance with the z1 tranny fluid changes. did you change out the 3rd and 4th gear pressure switches before too? keep us updated.
Well, with an 04 at 105K, you're certainly in the window for an APP sensor failure...Hope it's nothing more serious than that..
I'll keep you guys posted as I hear stuff. Also no, I did not do the 3rd and 4th gear switches, I was ordering them today along with the 105K parts.
They're going to tell you it's a complete failure regardless because they lack the skills to diagnose and even if they knew what was wrong they probably couldn't fix it. It would be nice if it were just the electronics though.
With that said, sorry to hear this. I'm right behind you in mileage and it seems like there's a new failure every day. I wonder if we should make the "racing atf" and "pressure switch" threads a sticky or write up a summary of both threads as a sticky.
Not that it matters now but if you plan to keep it, the switches seem to go bad every few years regardless of mileage. I'm not too far from replacing mine a second time. Just do that and the Type F fluid and you'll never have another failure.
To some of the others, oil jet kit addresses the second gear, gear lube issues. The normal failure mode is a trans lockup so it's not likely this is the cause.
Good luck with it. Looking forward to the updates.
Either way, if acura says that I have to fork out 4K for a new trans and then another 1K for the 105K service, it may be the end of the road for the TL and maybe even honda depending on how they handle it...
I hope their lead tech or whatever can actually diagnose it because it seems very odd that the car would just drop into neutral like that, and then stay in 1st and 2nd gear only. I hope its the 3rd gear pressure switch that failed and thus isn't allowing the car to shift into 3rd and above gears. But then again there was that burning smell so I'm hoping that something else didn't go...
Not good...I'm almost at 81K and seeing all these trans failures has me rather nervous.
I'm Craig
I'm slowly falling out of love with my car as I keep noticing more and more flaws. I sometimes just have to step back and realize there are greater issues to worry about and that many people would be ecstatic to own my car. Just is bothersome caring for an object so much only to have it spit in your face and dig in your wallet.
Guys, this has been gone over literally hundreds of times. Change the switches and use the Type F fluid and you will have no failures. There is nothing to worry about if you do this. Look at how many people have had a shuddering trans that was about to be rebuilt that the fluid and switches saved. There have been no failures of any transmissions on this board with this fluid and switch combo which is amazing considering most of them were originally switched over because they were already experiencing signs of excessive wear on the Z1. The only reason anyone would have to worry is if they have not done these simple "mods".
We now know the cause of all of the failures, we know the cure, and yet people still aren't doing them and they're posting about selling their car because of potential problems. It makes no sense.
o just wonder if TL-S transmission are stronger than the regular tl. I heard that tl-s have MDX transmissions. I think Rl's have same transmission and i never heard RL's transmission gone bad.
Stronger as in will take more and vehicle weight without breaking, probably. But a fluid with too much friction modifier (z1) causing clutch slippage along with switches that go bad every few years causing more clutch slippage will destroy any trans. No trans no matter how strong is immune to these two problems. That's why it's still important even for the TL-S guys to still do these two mods. Once you do this, you won't have to worry about the trans anymore.
That's waaaay off base. RLs do have the same problem, just not as often. A fluid and switch problem has nothing to do with where the transmissions were assembled.
Question is where switches where made, or other transmission parts were made??? For example alot people here, have problem with "tighten fuel cap" message and it is know that is due Purge Contol Valve (Very common problem). Valve is made in Mexico, rl's have same part and once again, i never heard that rl's would have same problem. Just example... By the way replacement that i order for Purge Contol Valve was made in Japan.
The only thing that would be relevant here is where the switches are made and if there's a difference in each model. My stock and replacement switches were Texas Instruments. I know where they used to be made but I have no idea if they're made over here anymore.
Any other trans parts do not matter because it's the fluid and electronics causing the failures, not the actual internal trans parts.
You might try posting your questions in the big switches thread.
engine made in Japan too, but i guess some valves, sensors ar not.
Lol. You should see how many of the exact same PMs I answer each day. I suggest at least every 3 years. Looking at some of the other failure threads, time seems to be more important than mileage.
Just found my tl-s window sticker. It is saying: Engine made in USA, Transmission made in USA. I called my buddy and he said that his car's sticker is saying that engine made in Japan. I guess varies because your transmission is made in Japan and mine in USA.
Sorry to hear about that, I'm waiting on a call back from my dealer. Going to try to speak to the tech and see if I can get the exact DTC code and figure it out with the Factory Manual and see if it's not a clogged sensor or stuck fork or something...
My 05 with 99300 miles just took a crap two weeks ago. Dealer replaced trans, power steering pump and side mirror actuator. Total cost around $5000, all covered under extended warranty. Never did fluid or switches. Going to let the new trans break-in for a few hundred miles then replace fluid with redline. Hope it works out for you.
SHAWD 04TL is in
Good luck my friend. I did a 3x1 recently in hopes of making this tranny last for another 100k at least!
If honda helps me out with a new trans (4500 for the trans, the 1500 for 105K service) to make it reasonable to keep the car, as soon as I get it past it's break in, I'm going Type F Lightweight on it and switching out all 5 pressure switches!
Good news! Honda got in contact with the dealer and said that I have to pay $850 and that they would cover the rest of the 4500 for a new transmission! Looks like the TL is going to stay with me for another couple of years![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Props to Honda and Acura!
Chapter Leader (NY/NJ)
if that was with the 105K service, It would be great. but 850 for a new tranny is still good.
Just thinking of all the A/t failures.... (known to Az) and its freaking crazy...
I hate cars should present something to acura about the pressure switches being part of the maintenance plan and get $$.
Dogmatic Dinosaur
You don't want them to open up your tranny. I would be shocked if any of them could even use a meter to check resting resistance on a switch. They are part swappers and instruction followers. Let them do what they are good at. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Don't forget that the new tranny will likely have all of the old externals on it - the switches still need to be done.
Definitely check that.
