Fuse for rear view mirror
The rear view mirror in my 07 TL-S doesnt dim. I'm assuming its a fuse issue...the only problem is, I cant find what fuse goes for the mirror...please help!
does your mirror tilt function when you put the car in reverse? does your windshield washer fluid work?
the reason i ask is because they all are on the same fuse, so if those two are working, and the mirror isnt ... most likely isnt a fuse problem
I had that problem last summer...I changed the fuse and everything started working except for the the rear view mirror...the green light doesnt come on
Fuse #20. There is a TSB to change it to a 10A fuse vice 7.5A.
Registered but harmless
Received 1,102 Likes
Technical Service Bulletin-- all of them are stickied at the beginning of the forum.
Yeah I pushed the button but it doesnt seem to be working.
rockyboy
12-06-2022 02:29 PM
BoricuaTL
04-08-2016 01:08 PM
dre707
09-08-2015 08:32 PM
