Front Sway Bar Replacement...DIY ???
Old Jun 15, 2012 | 05:35 PM
mattyd6911's Avatar
Id like to upgrade to at least a type-s sway bar on my 04 A/T, and Im not sure how to approach the job. Does anyone have a walkthrough or DIY with pictures or anything?? Some guidance would be a big help..
Old Jun 16, 2012 | 02:59 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
When I got underneath there it seems like we would have to partially drop the front subframe a bit. Not as easy as the rear.
Old Jun 16, 2012 | 11:36 AM
pohljm's Avatar
^ that is correct, not even in the same league as swapping the rear.
Old Jun 17, 2012 | 03:10 PM
mattyd6911's Avatar
I didnt think it was easy, but Id still like a DIY to see if I can manage..
Old Jun 18, 2012 | 01:33 AM
Bearcat94's Avatar
AZ Community Team
These are posted elsewhere, in one of IHC's threads maybe (?). If you search you might find some additional info - this is all I have.
Old Jun 19, 2012 | 09:44 PM
I hate cars's Avatar
No wonder I was getting confused. He has two spring threads open, two front swaybar threads, and two axle threads.
Old Jun 21, 2012 | 02:33 PM
mattyd6911's Avatar
Sorry for the confusion.. The noobie is learning....
Old Jun 23, 2012 | 09:40 AM
mattyd6911's Avatar
What would make the front of my car feel rough and jittery when I hit certain bumps, especially on the highway? I have Tokicos with the gay oem springs, all new bushings and arms, new PS rack, pump, tie rods, ball joints, engine mounts, Progress RSB, BF gforce comp 2 tires.... Anything with the sub-frame I could be missing, or do I need to upgrade the springs a bit? It very sensitive to the air pressure I have in
Old Jun 24, 2012 | 06:56 PM
paperboy42190's Avatar
Progress rsb does not affect the front end at all
Old Jun 25, 2012 | 12:47 PM
mattyd6911's Avatar
Any clue what could be causing this??
marcelft
Jul 10, 2018 06:17 PM
Onyxthecat
Oct 18, 2016 02:05 PM
drone619
Jan 26, 2016 07:09 PM
k6biv
Sep 10, 2015 06:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
