Found & Fixed my ticking rattle!!
Over the past couple months I started to hear this ticking rattle that would usually start up randomly on the highway and rough city roads. It sounded like it was coming from the rear deck and I was convinced something must be rubbing on the window or it was a sheet metal seam flexing somewhere.
Turns out it was under the headliner where the oh Sh*t handles attach. The metal mounting bracket would tick when flexing against the frame. The occurred right where it bolts to the roof toward the drivers side.
Also I also discovered the side airbag is wrapped with this very sticky tape that keeps it wrapped up during installation. This tape is very loud when it moves like a piece of cellophane plastic. I'm not sure if was causing audible noise but I felted between the tape and the headliner too.
Just wanted to share!
This rattle source was right inside the headliner where the weather strip is pulled down.
Slpr04UA6 (07-20-2013)
Good job- I had an ongoing rattle from my A-Spec pass side sideskirt for 2 years before I finally found it- silence is truly golden. You will really like your TL a lot more now.
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
