Fixed my motor mounts today!!
Just replaced my front, rear and side motor mounts with brand new OEM ones, and what a difference!! I love my car again, no more pulling to one side while on the accelerator, and no more shaking at idle. And my shifts feel much smoother. The culprit was my rear and side mounts. The rear was ripped and leaking and the side was in two completely separate pieces. Took me almost 4 hours, and the only hard part was the rear one because of lack of space.
that ONE RED tl
Damn I'm sore as f***. Did all 3 of my mounts yesterday and took my about 4 hours. Even though I was able to utilize my uncle's shop I did 95% of the work because my brother and uncle were busy building a roll cage for another car.
Like you guys said, side was a breeze (I wish they were all that easy). Front wasn't a big deal after removing the radiator fans, I found that I couldn't remove the driver side fan without removing the top hose. The rear was a bitch, just because of the awkward positions you had to be in, other than that, they were all pretty straightforward.
What really gave me a hard time was probably the simple things. Banged up my finger removing the vacuum line from the front mount, and had to do the rear over because I pinched the vacuum line without knowing and tightened down the bolts $#!+.
Another pointer... the front and rear are filled with fluid so if they're cracked... don't turn them upside down. I made that mistake with the front mount while messing with the vacuum line.
Once all is down, enjoy the clunk free driving and rattle free cold morning starts! ...and take some pain relievers the next day because you will be sore.
the overexplainer
Question, how do you tell if your side mount is broken? Is it if the plastic cap is cracked? when i had mine inspected that was one of the things that needed fixing. I didnt really want to pry the plastic cap off to look but at the same time I wasnt sure if that was a broken mount indicator of some sort.
that ONE RED tl
It could be an indication because I noticed that when my mounts broke, it slightly lowered the motor in the engine bay .25" to .5". If your side mount wasn't broken, that plastic/rubber cap would not have any pressure on it from the top bracket that it connects to, but if the mount was broken, the bracket is pretty much sitting on top of that plastic cap. Hope that makes sense.
the overexplainer
yea it does make sense. The weight of the motor is on the plastic cap now. Weird thing is though I can rotate the plastic cap as if there wasnt any weight on it..perhaps it's sitting on the other mounts.
I wasnt sure if the shop cut it open to look inside either. it's a pretty straight line/crack like someone took a dremel to it.
changing the front mount was a breeze, all you need is a long extension, i just removed the side(passenger side) and front mount at the same time and was able to lift the motor with a jack and i didnt need to remove the aluminum bracket the holds it to the motor. The only tricky bit was removing the rubber vac hose from the bottom of the mount. The side is simple and could be done at the same time as the front. As for the rear you need to remove the strut tower bar and then you need more some extensions and elbow extensions to get at the far nuts and bolts.
Hey speedytypes can you please give me more details on this install, I want to tackle this myself.
1.) Did you have to remove BOTH radiator fans?
2.) Did you have to remove the radiator hose to move the fans?
3.) On a rating scale of 1-10 with 10 being the hardest how do you think the rear is?
4.) Did you remove the rear from underneath the car or on top?
5.) The front mount with the vacumme hose, any tips as you said it was tricky?
6.) Did you noticed anything different after you installed the mounts, meaning do you notice any more vibrations and stuff?
Thanks!
Thanks!
No I didnt have to remove the rad fans, and no i didnt remove any hoses, and as for the rear i removed it through the top, on the drivers side, I just carefully manuvered it through the hoses and wires. As far as the ride it is 100 times better no more vibrating while standing still, and the engine feels alot smoother, i find myself forgetting to switch gears and driving at a high rpm just because i dont feel or hear the motor. And as for the vacume hose on the front i loosened the front splashguard or whatever its called on the front below the mount and just pulled the vac hose off the hard line first and then just pulled the mount out with it on.
