F-CAN Error Codes
Originally Posted by cbptls
The F-CAN is connected to the gauge control module, the ECM/PCM, the navigation unit and VSA. I don't have a list of the specific codes, but your trouble is in one of the above. Any other indications of malfunctions? Regardless, it's trip to the dealer time. At least you know the areas to look at. |
Thanks hameline,
Car was dropped off at the dealer yesterday. They said something about the brakes, hopefully they'll finish up working on it today. |
Modulator Assembly needed to be replaced.
Covered under warranty, otherwise a $709 part. |
My 07 TL-S has the same code .. dealer said it wasn't an issue
Same thing
Does anyone have any further information on this, like if it is or isn't an issue? My '07 has this exact same code/error showing (I can post an identical picture if needed) and it's been there for quite a while. The only problem I've ever had with the car was the Nav freezing and "rebooting" once shortly after I got the car. Since then, never an issue.
Thanks. |
