Engine/ belt Noise: Video link attached
Well, I've been dealing with this noise for months now and it's really hacking me off. I changed the serpentine belt and power steering pump back in march hoping that it would fix this atrocious sound, to no avail. From reading around I'm guessing it might be the timing belt tensioner? But I wanted to get a second opinion before I ordered any parts and brought it to the shop.
Here's the link:
Here's the link:
take off the serpentine belt, and start the car up.
yes, you will trigger some dash lights but you can then eliminate the pullies, idler ( even power steering pump...but you spent the money anyway ) as the cause of this noise.
it does sound on par with the timing belt tensioner
check out this vid
check out this vid
panzerkiller13 (06-23-2015)
The DVD-A Script Guy
check out this vid
check out this vid
Does the noise dissipate as the car warms up?
I have a similar noise that goes away completely when warmed. My mech says the oil is not getting pumped to the top as efficiently or something like that.
The noise in the video(s) above is almost definitely the timing belt tensioner. Cheap enough part, just a PITA to fix.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
