E-brake tightening
Old Oct 31, 2010 | 09:56 PM
rtibbitts07's Avatar
E-brake tightening
So I have searched, and checked the 3G garage, but I am unable to locate any DIY's or instructions on tightening the ebrake cable on my 6MT TL....
Can anyone point me in the right direction? I have to pull my ebrake all the way to the limit for it to take affect, which means it needs adjustment. Thanks.
Old Oct 31, 2010 | 11:11 PM
nfnsquared's Avatar
https://acurazine.com/forums/showpos...6&postcount=77
Old Nov 1, 2010 | 06:47 AM
VQPower37's Avatar
so the adjustment is done from inside the car? not the rear wheels?
Old Nov 1, 2010 | 07:57 AM
Turbonut's Avatar
Rear shoes should be properly adjusted before considering a cable adjustment.
Old Nov 1, 2010 | 10:01 AM
Thank you very much, going to do this later today.
Old Nov 1, 2010 | 12:21 PM
nfnsquared's Avatar
The cable adjustment is. If you want to do the major adjustment first, you can. I just did the cable adjustment and it worked fine. If you replace the rear parking brake shoes, you should definitely do both. Here's both procedures:
Old Nov 1, 2010 | 02:09 PM
I hate cars's Avatar
Once you do the cable and shoe adjustments, don't forget to break in the shoes for max power. Once you do the break-in, you may have to readjust.
Old Nov 1, 2010 | 02:12 PM
I'm guessing 6speeders dont generally have to do your "trick"
mine holds with no problem....I figure its only the auto guys since they dont use the ebrake often.
Old Nov 1, 2010 | 08:23 PM
Depends. Mine was never used except for when the car was already stopped. Doing it this way, they will never break-in......ever. Just using it won't break the shoes in. You have to use it while in motion to break them in. Mine held ok before but now it requires very little effort to lock in. It can easily lock up the NT05s.
Old Nov 2, 2010 | 01:28 AM
nfnsquared's Avatar
The cable adjustment is. If you want to do the major adjustment first, you can. I just did the cable adjustment and it worked fine. If you replace the rear parking brake shoes, you should definitely do both....
Update:
1. The Service Manual says 6-10 clicks for parking brake to hold.
2. Use Minor procedure for 1 or 2 click adjustment.
3. Use Major, then minor for adjustments more than 2 clicks.
Old Nov 3, 2010 | 04:26 PM
flipphinoi's Avatar
Thanks for the info. I too need to tighten my ebrake.
MilanoRedDashR
Oct 2, 2015 10:49 AM
jmaxima03
Sep 27, 2015 10:22 AM
SpraykwoN
ILX
Sep 24, 2015 05:20 PM
Brandle34
Sep 23, 2015 07:20 PM
Silverstead1
Sep 17, 2015 06:45 AM
