DRL ISSUE please help
ok.. so i purchased a set of white led lights from super bright leds and i installed them as is, plug and play .. now the issue they dont work when together i notice they work in series where if one bulb is blown they both dont work i tested this by pulling one led out and replacing it with a reg drl boom they both turn on i put both oem drls in boom they work. i put both leds in and ... nothing so i tested both leds individual and noticed that the driver side drl led works fine when tested with a stock drl on passenger side . now the other led bulb on the passenger side and stock drl bulb on driver side and nothing so i assumed it was the led bulb was defective and asked for replacement. I received replacement and installed and now same damn issue.. Is there something i am doing wrong. please help as this seemingly simple task is starting to piss me off.. TIA Matt
Dunno if I am of any help .. but I do know if one goes out they both quit and you get the indicator on the dash ..
Put the stock ones back in and if they both work then its the LED.
Sounds like you need a resistor in there or have to ground the LEDs...I am pretty sure it's not a problem with your LEDs but rather with your setup.
I got the same problem with set from VLEDS.... It's just the LEDs that suppose to be Plug and Play no KIT . I contacted VLEDS and they said that I DON'T need resistors then send me second set that does exactly the same thing
sockr1
10-01-2015 01:31 AM
