Drivers side window rattle when all the way up
My driver's side window rattles only when all the way up (no rattle when partially opened at all) and I can't seem to figure out why. It's at all speeds gets worse as the speed increases, unless the road is perfectly smooth.
I searched around the forums but couldn't find the same problem. I checked the sunglass holder in the door and also the electronic seat adjuster, but to no avail. Anyone else having this problem or know what it could be? Have an appointment with the Dealer tomorrow morning let's see what they say... |
check the wood/carbon fiber trim that is one the door. If you press on it, does it go away? also check the screws on the door panel as well.
So it turns out when I got my tints the guy accidentally cut into the rubber at the bottom of window and there was about a perfect 12" slice. That's what was rattling.
Dealer fixed it and the tint guy was reluctant at first but paid for the dealer replacement after 5 minutes of persuasion. Sorry if it didn't help! |
