drivers door lock
Old 10-07-2009 | 04:12 PM
bbailey's Avatar
6th Gear
drivers door lock
just noticed that my drivers door does not lock with the switch on the door or the remotes that I just programmed. Not sure if it started when I programed the remotes or shortly after. I have been through the programming on the dash and set up the "unlock when shifted to park" etc. Removed the door panel and everything appears to look okay. Any ideas? Am i missing something.
Old 10-09-2009 | 07:24 PM
Suh-C's Avatar
Probably the door lock actuator. I had to replace mine a few months ago. Make sure you test the actuator before you replace it to be sure.
rockyboy
08-04-2024 11:35 AM
tman570
06-11-2019 08:56 AM
VA2000TL
10-02-2015 09:26 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 11:40 AM
michaellong77
1G CL Problems & Fixes
09-11-2015 01:54 AM
Quick Reply: drivers door lock
